Hi guys, just dropped the prado in for a service, and was talking to the owner, and he recommended to add two stroke oil to each tank of fuel, helps lubricate and quiten down the engine? Anyone use this? I've heard of it being used in the older diesels.. thoughts guys? Cheers Odog
Two stroke in fuel?
Originally posted by O Dog View PostHi guys, just dropped the prado in for a service, and was talking to the owner, and he recommended to add two stroke oil to each tank of fuel, helps lubricate and quiten down the engine? Anyone use this? I've heard of it being used in the older diesels.. thoughts guys? Cheers Odog
In 1KZ it does absolutely no harm. I have used it to make AVTUR (kero, a "dry" fuel) into usable diesel type fuel. 4L into a '44 is the mix.
In 1KD I can't speak from experience, but I could see no harm in it at the usual concentration recommended, about 200:1.
They are all hydrocarbons, after all.
cheers
SteveLast edited by t303; 24-08-2017, 06:48 PM.
cheers
Steve
So thought I'd check on PP, to see what comes up..
The oil is meant to replace the sulphur lubrication now that we have ULSD, allegedly the current additives in diesel do the same job. I use it because "it could'n hoight!"
It is in negligible concentration and will combust just like it does in a two stroke engine. Check out your oil when you change it, do you think a little bit of two stroke oil in the diesel will make any difference at all in soot? The only unknown I can see is the effect on a DPF, but once again, given the concentration, it couldn't be any worse than what passes for diesel in some parts.Last edited by t303; 24-08-2017, 08:46 PM.
I ran in in my 1KD after about 100K km up until I had the injectors swapped out at 120K km. It was definitely quieter but there was no difference in fuels economy. 0.3% (300ml to a 100L fill) mineral based, low ash oil was what I was recommended. #### did the injectors and said there was no benefit to it with the DLC injectors, so I've stopped.
In terms of quietness, I'd say the old injectors (which had a bit of rattle) with 2 stroke sounded pretty close to a new set with no 2 stroke.2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
2008 Jayco Dove Outback - "Davo"
Originally posted by Phs View PostWould Not recommend for CRD ( D4D )
But will work well with older non CRD fuel systems
http://www.fuelexpert.co.za/2-stroke...ical-study.php
more detailed in regards to impact on older diesel system system but in German:
https://matsch-und-piste.de/zweitakt...er-schaedlich/
Seems like the more "quiet engine" is achieved by have reduced power due to less effective burn by adding 2stroke oil
