Extending GME UHF Antenna
  • Extending GME UHF Antenna
    Hi All,
    i have moved my antenna on my 150 to the side of the bull bar and this has made the tip of the antenna lower than the roof line.
    The whip part of the antenna is around 60cm long and unscrews from base.
    Can I purchase a longer whip section to replace the app costing one and raise it above the roof line?
    thanks.
    2012 Prado D4D GXL. Graphite.
    Yes you can swap the whip out for another brand that may be longer provided it's for UHF CB.
    One thing to note the longer antenna may be a higher gain such as a 6db or 9db, these higher gain antennas throw the signal quite flat. This gives a longer range on the plains but wont be as good in hilly areas.
      Cheers.
