Rear e locker light on cluster
  • Rear e locker light on cluster
    I want to install a rear elocker in my 150 gxl with a factory switch and want to know if theres a rear diff lock indicator symbol in the instrument cluster that can be illuminated when the locker is activated?
    Otherwise I'm not sure how to tell if locker is on or not using oem button.
    There's one in the Kakadu for the factory rear locker. It's red and is just to the right of the yellow centre locker indicator in the middle of the speedo. It also gets indicated with a red cross over the rear diff in the multi-function display.
      Yep gotcha. Thanks. I have a GXL though, do you know if its possible in a gxl?
        I did this on my old 120 GFORCE120, not sure if it's any use but see here for ideas:
        http://www.pradopoint.com.au/showthr...ker+dash+light
        Micheal.
