TRJ120 2007 Prado ABS & Warning Light Pops On
  • TRJ120 2007 Prado ABS & Warning Light Pops On
    I've posted this on another forum, Toyota Nation, and there was no result.
    I'll copy/paste the content from there.
    I just changed both of my front wheels' wheel bearings, because it was starting to break down.
    I've taken great precaution about the wheel bearings' inner & outer side, and triple checked it.
    After changing the wheel bearings, the ABS & brake system warning lights popped on, and after scouring the internet, and ended up in TN, I tried to reset the error by short-circuit pin 4 & 13 on the OBD, and it worked, or so I thought.
    After short-circuiting pin 4 & 13, the ABS popped back after about 200m, and then the brake system warning light too after about 1km.
    I tried resetting again, and the problem comes back under the same condition.
    The original wheel bearing was NSK, and I changed it with Koyo wheel bearing.
    I was wondering whether the ABS sensor is only suitable with NSK. I have checked the brake fluid level, and it's normal.
    abs sensor is in the wheel bearing, you must have got the wrong bearings
      Or you've damaged a cable. Which is easy to do.
      You need to put a code reader on it to see what codes are being thrown.
