Results 1 to 9 of 9
  1. #1
    Join Date
    Feb 2014
    Location
    Seaford Rise
    Posts
    156
    Rebuilding a D4D
    So my latest adventure has come to a premature end. Sudden loss
    power smoking and dropped onto 3 cylinders. Fortunately before crossing the Simpson!
    Injectors were replaced 20k ago as readings 2.4 on 1
    Cyl. EGT normal then went sky high - all happened in space of
    5 secs and injectors recently checked.
    So I want to hear from anyone who has rebuilt their
    own engine as to the success they had doing it.
    Please don't comment with buy a Toyota new engine
    as not a viable option for me! Thanks
  2. #2
    Join Date
    Aug 2008
    Location
    Brisbane, QLD
    Posts
    782
    Give a rebuild place a call and see what they quote. Don't use Toyota pistons for the rebuild as they're known to be weak.
    2008 GXL D4D + Option Pack 1, Safari snorkel, factory alloy bar, dual battery system, Lovells TFR-118/TRR119 Springs, Bilstein Shocks, Prodigy P3 brake controller, factory tow bar, Orac coupling.
  3. #3
    Join Date
    Feb 2014
    Location
    Seaford Rise
    Posts
    156
    Thanks going to do exactly that but was interested in brands for that very reason
  4. #4
    Advanced Member Razorback81's Avatar
    Join Date
    Sep 2012
    Location
    Lewiston SA
    Posts
    559
    how bad is the block ?
    toyota have the new 010 pistons to replace the original pistons that were weak
    i am interested in seeing it apart, i have one here that i was looking into pulling apart it has a broken balance shaft
    cheers James
  5. #5
    Member Hogey66's Avatar
    Join Date
    Jan 2016
    Location
    Queensland
    Posts
    246
    [QUOTE=Razorback81;575715]how bad is the block ?
    cheers James[/
    Have a look here...
    http://www.pradopoint.com.au/showthr...-HELP!!!/page4
    Plenty of info on deleting the balance shaft altogether
  6. #6
    Join Date
    Feb 2014
    Location
    Seaford Rise
    Posts
    156
    Looking at ceramic coated pistons with extra oil jets should be out of trouble for $3200 inc head overhaul with me assembling!
  7. #7
    Join Date
    Feb 2006
    Location
    Sydney, Australia
    Posts
    213
    Where did you get the pistons from?
  8. #8
    Join Date
    Feb 2014
    Location
    Seaford Rise
    Posts
    156
    Engines Australia do them but only to order - you are looking at a 3 week wait to Ceramic coat them. Unfortunately my block is already at 040 even though the car has only done 139000 kms. Have sourced another motor potentially but am going to start another thread to see if anyone has used them.
  9. #9
    Join Date
    Aug 2008
    Location
    Brisbane, QLD
    Posts
    782
    Can 1kd's have liners pressed in after boring out the block?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
