Prado 150 centre console double switch
  • Prado 150 centre console double switch
    Hey all! My 2011 Prado 150 Kakadu is not fitted with crawl control and therefore has a blanking plate on the center console. The plate is the same slightly taller and doubles the length than that of a standard switch. I wanted to know If I could install two side-by-side switches in place of the plate and maximise my real estate, but unfortunately they do not fit (it seems like it needs a bracket). Has anyone overcome this issue? If I can't figure a way, I'll just drill through and use it as my UHF handset connection point.
    I think the manual version GXL's have a switch plate with two sets of switches on both sides of the 4wd selector. You may find that this plate it is interchangeable with the auto version.
      Thanks for that, I'll see what I can find. I wish they made an adapter that fit in, allowing for an additional 2 switches
