Has anyone changed the fuel sender unit for the main tank b4?
  • Has anyone changed the fuel sender unit for the main tank b4?
    I know the LH rear seat needs to come out (4 bolts by the look of it), easy.
    Then there is a fuel system access panel to remove (3 screws). After that I'm stuck as I've never taken this access panel off.
    Where is the sender unit from then on? Do I have to undo a heap of a petrol tubes to remove the fuel pump and then the sender unit? Do I need to drop the tank at all?
    I actually dropped my tank down when i was chasing the mystery fuel block and later learnt about the panel ARRRR.
    Once you open the panel you will see a really big plastic type ring that holds the unit and all else in there. You can get a special tools to turn it but i ended up using some rope and leverage to turn it as well as taping it gently to help. It's plastic so it will break if you are too rough with it. Once that's unscrewed the whole unit just comes out.
    Here's a few pics i found for you.
    Also, check this post out to have some more details.
    http://www.pradopoint.com.au/showthr...l-to-clean-out
      Thanks heaps for those pics.
      I don't have a hoist and only 1 decent jack. Might be a job for l8r.
