Extended factory roof rails
  • Extended factory roof rails
    I have been looking at a roof platform flat rack for the car
    The platform is 2100mm long and I think I would like to fit 3 cross bars under it
    I have 2 Rhino Aero bars already
    To do that , I reckon I would need to lengthen the fixed, longitudinal roof rails
    Without doing that, the distance between rails would be about 1000mm with a 550mm overhang at each end
    Is there an extension kit available to lengthen the roof rails ?
    Pete
    For the 2100mm long platform, you need to remove the rails and fit it directly to the roof.
      Pete
      I recon you are better off without the factory rails and fitting a platform using platform feet, that way the platform is closer to the roof, you have more clearance, less wind resistance and its better all round.
        Good idea
        I will go that way
        I was trying to set it up for use on 2 vehicles
        Pete
          Hi Pete,
          I have just gone through this last Thursday. Removed the factory rails off my 120 series as there is a 20kg gain by going direct to the roof / support pillars as well as it sitting alot lower for multi-story car parks, home roller doors etc.
          Happy with the 2128 length over the 1928 and it is recommended for the 150, 100 & 200 series also for upgrades.
          Good luck!
            Thanks SLR
            I will go that way and get a different set up for the other vehicle
              did you try the Rhino backbone as a base?
