Results 1 to 6 of 6
  1. #1
    Senior Member fourbyphil's Avatar
    Join Date
    Dec 2010
    Location
    East Maitland, NSW
    Posts
    398
    Changing Rear axle seal
    Hi All,
    Found a fairly decent oil leak on my left rear axle.....Z2L3OKbfSWGWhtBQ14y1xw.jpgZ2L3OKbfSWGWhtBQ14y1xw.jpg
    Time to pull it apart.....
  2. #2
    Join Date
    Nov 2009
    Location
    Cherrybrook, Sydney
    Posts
    415
    Hi Fourbyphil
    Can you tell us more about this repair? I found a leak on my wheel that look like diff oil. I've been told that you cannot just replace the seals, you need to replace the whole hub assembly. Cost of the parts alone is $300 with similar for labour. My 120 is now 13 years old with 190K on the clock. When I first saw the leak I thought it may be a good idea to get both done considering the age, but now I'm not so sure.
    2004 GXL V6, full house
    My build up here http://www.pradopoint.com/showthread...ng-2004-GXL-V6
  3. #3
    Join Date
    Feb 2006
    Location
    Sydney, Australia
    Posts
    224
    You can replace just the seal but you should also get the oring too that goes between the axle tube and flange.
    Drain diff oil, unbolt the brake.caliper, remove disc, remove the 4 Bolts holding the axle carrier flange to the axle tube and it will slide out revealing the seal.
  4. #4
    Join Date
    Feb 2006
    Location
    Sydney, Australia
    Posts
    224
    $300 for labour is reasonable but the parts is a bit exxy. You may also want to check the handbrake shoes and brake pistons at the same time while is all out.
  5. #5
    Avid PP Poster! foxclan's Avatar
    Join Date
    Jul 2008
    Location
    Adelaide, SA
    Posts
    1,283
    Quote Originally Posted by Boomslang View Post
    Hi Fourbyphil
    Replacing the whole hub sounds like your informant may have been thinking of the front axels?
  6. #6
    Join Date
    Feb 2006
    Location
    Sydney, Australia
    Posts
    224
    Front hub seals are also individually replaceable
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
