ARB bullbar cutting template
  • ARB bullbar cutting template
    Hi all.
    I picked up an ARB bullbar for my 150 prado.
    I believe it's a deluxe bar.
    ARB are unable (unwilling) to provide me with a cutting template for the plastic bumper.
    I have searched the forums and internet but come up short.
    Anyone happen to have one one file that I can print out?
    Prado 150 V6
    Wouldn't it come with the fitting instructions?
    Have you contacted ARB head office or just been going through the local ARB agent?
      Sorry, should have mentioned I purchased it used so it didn’t come with any instructions.
      I haven’t tried the head office, only a couple of different store.
      Prado 150 V6
        stephcott
        2013 GXL DIESEL AUTO, ARB BULLBAR, IRONMAN SUSPENSION, TOYO OPEN COUNTRY A/T2, JAYCO DISCOVERY OUTBACK
          Originally posted by stephcott View Post
          PM me your email address and I will send it to you.
          Phil
          Apparently private messages are down, I went on your profile and sent you a message there.
          Thanks mate
          Prado 150 V6
            Hi everyone i'm in the same boat picked up a second hand ARB winch bar and no instructions or cutting template any help would be much appreciated
            Cheers Luke
              p.s no too worried about instructions just the template
              thanks in advance
                If you send an email to ARB head office asking for a copy of the fitting instructions and template for
                the bullbar part number they should be able to help you out. I did this and the manager of the
                closest regional office emailed me the instructions within a couple of days. Very good service I thought.
                  Thanks Bugga will do.
                    Just fitted one to mine - if you're fitting a winch, make sure you install the two captive nuts for the undertray BEFORE fitting the fairlead.
                    That little gem is under the tray fitting instructions - which is no use if you fitted the winch a couple of days earlier following the 'optional winch instructions'!
                    Also trim back the inner plastic guard before you tighten up the side wing trays.
                      Discovered another gem - wire the plug for the parkers/indicators when the grille and bumper section are off. That way you can remove the headlight to access the wires without having to break an arm to get into the indicator plug.
                        Reviving an old thread!
                        Someone from ARB sent me the template however there seems to be a page missing? It says it’s page 1 of 1 but it also says I need to join it to the other sheet?! When I cut it it’s definitely too small. Anyone got the complete template?
                          It is symmetrical around the centre. Print two and join then where it says join line as it shows in the second page of the instructions.
                            Thanks mjrandom.
                            I ended up emailing them again and they got me the second template. Seperate part no. for the each template which is odd to me. Either way I’m a pm away if anyone needs it.
                              Originally posted by Boged4lyfe View Post
                              Thanks mjrandom.
                              Hi Bogged4lyfe, have you still got a copy of the templates and instructions you could send me? I’ve sent you a PM.
