Hello
I have a KZJ95 manual which is getting close to 600,000km. I regularly check under the vehicle as i have had seals goes on the diff and transfer case before. Today i was under her as i am going to do an oil change. When i went under i noticed some wetness on the diffs short shaft, i checked and it was engine oil and above it is the turbo housing which was wet underneath and had a couple of drips on it.
Any ideas about what could be causing this?
