Where is the oil pressure sensor on a 1KD prado
  • Where is the oil pressure sensor on a 1KD prado
    As per the title, does anyone know where the oil pressure sensor on a 1KD is located, according
    to the parts diagram it is on the left side of the motor. I have had a look but can't see it anywhere near the filter unless it is buried behind the engine mount solenoids?
    Alternatively is there a plug on the oil filter mount that I can use to access the high pressure oil
    flow, ie an oil pressure test port?
    Found it covered in mud beside the filter:
    LeighW
