Page 2 of 2 FirstFirst 12
Results 13 to 22 of 22
  1. #13
    Lurker
    Join Date
    Feb 2016
    Location
    Geraldton
    Posts
    21
    Hi Guys
    OK cleaned maf sensor & map filter
    maf not really dirty but drowned it anyway
    as for map filter , I think I found the right one, as well as being a filter it's a one way valve as well
    so gave it a shot of cleaner thru it had a fair amount of crud in it
    made slight improvement, so have ordered new filter ( $55 ) toyota know how to charge for little plastic bits that are only 25 mm x 25 mm.
    toyota don't call it a map filter , it's a gas filter, so should get it tomorrow & see if makes anymore improvement.
    as for techstream cable got one that doesn't work for me, so a bit apprehensive about getting another one, got refund and was able to keep it's a 32bit (was supposed to be 64 bit).
    I'll get one eventually
    Tony
  2. #14
    Lurker
    Join Date
    Feb 2016
    Location
    Geraldton
    Posts
    21
    double post sorry
    Tony
  3. #15
    Join Date
    May 2010
    Location
    Sydney
    Posts
    817
    How many km's since your injectors were replaced if ever? The general consensus for non DLC injectors is to change them at 120,000km. I had my injectors done on my 150 slightly earlier than that and the engine is definitely quieter. Quieter than it was when new in fact.
  4. #16
    Lurker
    Join Date
    Feb 2016
    Location
    Geraldton
    Posts
    21
    Hi Riv39
    Never, only got 107k on it, being a early 2013 model will be getting it checked soon.
    Tony
  5. #17
    Avid PP Poster! Corigator's Avatar
    Join Date
    Sep 2008
    Location
    Sydney
    Posts
    1,294
    Blog Entries
    1
    New full coated injectors will definately quieten it down
    Greg - 08 D4D Prado,
  6. #18
    Lurker
    Join Date
    Aug 2015
    Location
    sunny coast queensland
    Posts
    21
    got the same rattle
    new injectors did nothing for the noise
    have owned from new and has been over serviced
  7. #19
    Join Date
    Mar 2015
    Location
    South Australia
    Posts
    135
    Quote Originally Posted by cannoballs View Post
    got the same rattle
    what oil have you been using and has it been same from new?
  8. #20
    Out of control poster! amts's Avatar
    Join Date
    Jun 2009
    Location
    Adelaide, SA
    Posts
    9,604
    got the same rattle
    What was the injector feedback volume after the replacement?
  9. #21
    Lurker
    Join Date
    Aug 2015
    Location
    Posts
    21
    havnt check amt but they are the ones from you
    I need to get them recoded and see if that fixes it
    oil is the same penright oil I have used since new
  10. #22
    Join Date
    Mar 2012
    Location
    Prague, Czech Republic
    Posts
    71
    Well, it's not the MAF sensor for me; I clean it regularly when I replace the air filter, and I just did it again. Cold knock is still there. Also replaced the oil - the sump screen (which I check each time) is also clean.
    I'm a little worried based on what I read on this page of Bailey's website: "The Common Rail injectors fitted to 1KD engines are fairly problematic and can cause significant engine damage if left unattended. Most common failure mode is known as ‘cold knock’ which essentially sounds like there is a major fault with a bottom end bearing – only whilst cold.
    Fault is caused by the spindle in the centre of the injector seizing / sticking when cold, which causes an excess of fuel to be inputted into the cylinder."
    According to them, if the values are beyond +/-2.5mm3 / stroke cold or hot, that could be the problem. I'll get them checked, but if if my already-replaced Denso injectors, which only have about 70,000km on them (the car has 260,000 km on it) are out already, I won't be pleased.
    __________________________________________________ __________________________________________________ __________
    2003 LC120 (European Prado) 1KD-FTV 3.0 D4D. All stock including standard transmission. Apparently not one of the VIN numbers that has an injector seating problem but keeping an eye on it anyway....
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
