Oil leaks 2007 D4D Auto
  • Oil leaks 2007 D4D Auto
    Hi all,
    I am hoping you can please give me some advice. I am looking at buying my first Prado. This one is not the tidiest Prado on the block, however it runs and drives pretty well, it's at 230k, and has no documented service history. There is an oil leak coming from the turbo, it is from the back of the front impeller housing, don't think it was from the drain. Do you have an ideas if this could be detrimental to the ongoing serviceability of this vehicle, what could be the exact origin of this leak, and would it be fixable by the handyman mechanic (me)? There's a couple of other leaks including small leak mid gearbox area. TIA, Mike.
    There are a few threads on this. Here's one. http://www.pradopoint.com.au/showthr...-leak-2012-D4D
      at that many k's has it had injectors , if not you would need to budget that into the sale
        Thanks...I've done some more reading since I posted. Looks like it might need a professional eye over it.
          Thanks....there's no way of knowing. At the moment it's running fine, no service history as previously stated, I've just got to take it at face value and accept I might get stung down the way a bit. Might try and get a Techstream if they are still available, and keep an eye on them.
