Kakadu Tow Capacity GCM upgrade
  • Kakadu Tow Capacity GCM upgrade
    www.climaxsuspension.com.au/gvmprado150.php
    Anyone have any experience with these guys ?
    They're the only ones who can upgrade the Kakadu's
    Slips
    So doing the calcs:
    Kerb weight: 2445kg
    New GCM: 5990kg
    Van: 3000kg
    Towball: 300kg
    GVM: 2990kg
    Payload: 2990-300-2445 = 245kg
    That's 3 adults with no accessories or luggage. Hmmm...
      that's the big issue i have been having
      the weight Toyota say my car is by the vin plate is 1995kg but the GXL is 2350kg
      if you take 8 people at say 75kg as the average & fill it up your 200kg over gvm before you add tow ball weight, and that is without any gear onboard
        Perhaps the brochure fails to mention a GVM increase is also included?
        Anyway, right below the comment about the kakadu they show a picture of four coils and judging by the colour, polyair bags.
        Show me a suitably qualified suspension engineer that recommends airbags (coil assist bags) for heavy towing...
          There is no change to the GVM because they state the GCM of 5990kg. Take away the van weight of 3000kg and the GVM becomes 2990kg.
          Edit: Correction. If the van weighs 3000kg and the ball weight is 300kg, then the ball weight is transferred to the vehicle. So van is 2700kg without the ball weight. 5990 - 2700 = 3290kg (GVM).
          amts
          Ninja Poster.
            Good point, my bad.
            So then it's an 'on paper' towing limit (like the current crop of dual cabs) and is probably useless in the real world!
            Slippery - FWIW are you able to take your rig over a weighbridge? I'd be interested to see the weight BEFORE all of the luggage, passengers and Tow ball load.
              Originally posted by 120D4D View Post
              Good point, my bad.
              No you're on to something. See my edit above.
                I think you were right initially and GVM remains at 2990, also it would be unusual to present the numbers that way to assume a change in GVM.
                Only the approved documents can be relied up but I note that the image showing the tow capacity shows CGM at 5990 no mention of GVM.
                  If they missed adding in the updated GVM, then the edited calculation is correct. However the updated GVM still needs to meet the manufacturer's axle load limits - which is... (?)
                    I have it as 3250kg (1450 front & 1800 rear) so GVM increase (if there is any) has to be less than 3290 unless they are increasing the axle limits also.
                      has yours been done ?
                      i have a pic of a plate on a prado that has had a GVM upgrade to 3250kg
                        so is this what your saying?
                        van weight is 2350kg off the car
                        van weight is 2130kg on the car
                        so give 220kg ball weight
                        so am i towing 2350kg or 2130kg?
                          No mine hasnt. that 3250 lines up with the axle limits - as expected.
                          ha! - you're still towing 2350.
                          Your van plates might reflect a 2,350kg ATM with a 2,130kg GTM and 250kg TBM but the GTM figure is much less important than the ATM and TBM as these are limited by the vehicle or tow bar manufacturer.
                            so if i am towing 2350kg
                            does the 220kg get counted on the car in the GVM of the car?
                              Yes, you need to deduct (or add, view dependant) the 220kg's from your GVM capacity.
