Performance Chip for 1KZTE Motor
  • Performance Chip for 1KZTE Motor
    ITEM: Safari DTronic Diesel Performance chip for Toyota 1KZTE motor
    CONDITION: Excellent
    REASON FOR SELLING: Car has been sold
    PRICE AND PRICE CONDITIONS: $450 - Or any reasonable offer. Will post at buyers cost if necessary.
    EXTRA INFO: No extra fittings necessary, this unit plugs directly into the ECU. Detailed manufacturers instructions included.
    PICTURES:
    geo
    [COLOR=#b22222]Prado 150 2.8 GX Auto - ARB Bull Bar, Towbar, Dual Batteries, UHF, 2" lift with King Springs & Bilsteins[/COLOR]
    What model prado does it suit?
      It was from a 90 Series. I don't know whether the ECU changed for the early 120 Series that had this motor.
        This is a SD-180 from the photo, as mentioned fits the KZJ90 series, SD-181 fits the KZJ120's.
        As the what the differences are, I'm not sure.
          No worries iv got a 120 ecu, there different to the 90 not having a od off switch and the throttle switch is different there also a faster ecu
            Would you post to the UK or US? please PM me
              Hi Geo - Just wondering if this module is still available and how much power and fuel efficiency did you gain please? Cheers, Ben
                I had one on from day two of purchase (second hand) in 2009. Power increase marginal, fuel "efficiency" unchanged if you are burning all the extra, Safari used to claim 10% with snorkel and exhaust fitted at the same time. It was obviously adding fuel because the EGTs could be pushed over 750C, a situation that remains to this day. Snorkel followed, but the most noticeable change made was the last, removing the stock muffler and replacing with straight through. More gasflow to enable the extra fuel to be burnt, with (finally) my desired effect of lower EGTs (by 60-100C) so that I could use the power. So, if you fit the chip do the muffler at the same time.
                cheers
                Steve
                  Hi Steve - Thanks for the valuable tip mate. Really appreciate it!
