Aircon not blowing properly
  • Aircon not blowing properly
    Gday all, I have a 2014 150 prado, the airconditioning is still cold, however its not blowing as strong as it once did, I suspect the evaporator core may be covered in lint but not exactly sure. has anyone pulled the evaporator out before?,, looks like a major job, or is there a filter of some sort in there, cheers
    G'day mate
    There is a filter behind the glovebox.
    You need to remove glovebox and it's right behind it , slides in , it's about 150 mm square.
    Hope this helps
    Tony
