How to access fuses in Prado TX
  • How to access fuses in Prado TX
    Hello, I blew the 100 AMP ALT fuse in my 1996 Prado TX and I have been unable to figure out how to separate the fuse box so that I can get at the screws holding the fuse in place. A detailed explanation would be very appreciated as i have exhausted You Tube with no luck.
    If you unbolt the fuse box from the body you will be able to then push the fuse block up after the little tabs are bent over. The tabs are in the main box
      There's a good "how too" here with pics for 120/FJ, how similar to the 90 it is!
      http://www.fjcruiserforums.com/forum...placement.html
      MalP
      2007 120 D4D GX. Duel Battery, Secondary Fuel Filter, Safari Snorkel, Uniden UH7700NB/AT870 antenna, Scangauge II, King/Bilsteins lift. Rhino rack Pioneer Platform. Maxtraxs and homemade rack side mounts.Awning. And the to-do list is still long.
        Thanks for your help. I had already unclipped the tabs and separated the fuse box. I was eventually. with help, able to figure out that the fuse receptacle holding the ABS 60 fuse had tiny clips on its ends that had to be released in order to push that receptacle down and give access to the ALT fuse.
        chrismontez
        Last edited by chrismontez; 25-11-2017, 08:58 AM. Reason: Success with the project
