Hi,
Has anyone installed any of the redarc 52mm gauges? These are space-saving as there can be 2-3 gauge measurements per unit, instead of the usual one measurement only.
https://www.redarc.com.au/monitoring-gauges-g52-eb
Redarc mentions that it only works with their sensors. Where and how do we install their sensors? Or should the Toyota sensors be removed/replaced by the redarc sensors, which then disables the Toyota sensors and ecu connection.
Also, does the gauge have a screw-in ring in the bezel to lock it in position in the gauge pod?
Thanks!
Thanks!
