I have just upgraded from 2014 3.0L 5 speed auto to 2018 2.8 D4D 6 speed auto. Nice and quiet to drive compared to the 3.0L 5 spd.
First run up into the hills today and the Scangauge showed Transmission Oil temperatures that were much higher than the old vehicle.
Around town 5 speed showed 78 degrees Oil pan and TC. Went up when the torque converter unlocked but after the torque converter locked again the temp came back down after a few Kms. Even when towing, ATF temp might go to 100 through the hills but would be back to 78 after less than 5 minutes once going down hill.
Driving the new one through the Adelaide hills today both temperatures went up to around 100 and stayed there (plus or minus 5 degrees) even on long downhill runs. After a 10k run downhill and about 10K of city driving to get home the temps were still in the 90s. Even letting it idle at home for 5 minutes the temperatures did not drop.
Would anyone with a 2.8 D4D 6 speed auto and a Scangauge post the temperatures that they see doing the same sort of thing and also when towing as that is what the vehicle is primarily for. I tow 2.4T caravan but have not got the brake controller on this vehicle yet.
The old vehicle has towed the caravan 30,000+km and I never had a problem with the scangauge readings. It is a concern when this vehicle is rated to tow 3 tonnes but with even no load, ATF temperatures like above make it look like an extra oil cooler is needed.
Steve
Scangauge codes I am using:-
Torque converter Temp
TXD 07E02182
RXF 046105820000
RXD 3808
MTH 00010001FFD8
Transmission Oil Pan
TXD 07E02182
RXF 046105820000
RXD 2808
MTH 00010001FFD8
Steve
TXD 07E02182
RXF 046105820000
RXD 3808
MTH 00010001FFD8
TXD 07E02182
RXF 046105820000
RXD 2808
MTH 00010001FFD8
