Auxiliary Fuse Panel - Part 1
  • Auxiliary Fuse Panel - Part 1
    So I started by adding a second battery and Redarc BCDC1225LV to the Prado 150.
    While at the shop I noticed they were selling auxiliary fuse panels in various stage packages.
    I went home and wrote down a list of accessories that I intend and also a wish list and designed my own system.
    The accessory panel (30A max per fuse) has 20 blade type and 3 MIDI fuses mounted on it.
    The panel is split into two gangs, the first 8 fuses have power supplied by the main start battery and are isolated by a solenoid activated only when the ignition is on.
    The other 12 are powered 24/7 by the second battery.
    I incorporated a moment switch to bring both batteries together via the Redarc wiring diagram.
    I ran a positive and negative cable to the rear to power a rear sub board which I will put on the next post.
    Parts sourced through Allanco whelspool road, The 12volt shop Kewdale road and Connect source in Midland for Dutcsh plugs
    Found a spot to mount the fuse panel in the engine bay
    Made a paper template Click image for larger version
    Laser cut sheet metal Click image for larger version
    Bending sheet metal Click image for larger version
    Mock build up of panel Click image for larger version
    Completed install Click image for larger version
    Part 2- Rear power
    I ran a dual 4B&S cable through the firewall and passenger side of cabin to the rear.
    The panel runs into a ganged 4 outlet fuse panel which feed two cigarette outlets on the drivers side for running fridges and two relays which power a rear and awing work lights switched from the dash board.
    There is also a 50 amp MIDI fuse to protect the Anderson plug on the tow bar.
    Cable run to rear of vehicle Click image for larger version
    And (had to trim the under sides of the scuff panels) Click image for larger version
    Found a spot to mount rear sub panel Click image for larger version
ID:	656528Click image for larger version
    Paper template and mock build Click image for larger version
    Things I would change if I did it again, maybe if/when we upgrade to a newer model;
    1) I would get the harness professionally wrapped by Connect source instead of using plastic tubing, this would save a lot of space.
    2) I would also install a plug mounted to the fire wall instead of cable protruding through grommets.
    3) I would try to use the low profile miniature fuses as used by Toyota to keep fuses the same.
    4) I would try and source smaller fuse and relays (maybe same size as Toyota) as space is a premium.
    5) I would run the rear power to the Anderson plug via a solenoid so when the ignition is off the power to the plug is off.
    6) Even though I have run the cables I would install some volt gauges for the batteries.
    7) Maybe a Lithium battery to save weight and have more power capacity.
      nice job Halsey.
      you wouldn't happen to have a copy of the templates you made? I'm in the process of installing dual batteries and rear power sockets and recon your templates would make the job a lot neater
      Rabs
      2013 GXL Prado KDJ150R
        Had three laser cut, stuffed up one bending them, still have a spare if you want it?
          That would be great. Let me know details via PM so I can pay you for it.
