Mounted my Icom IC-450 recently into my 150 GX, found a nice hidden away spot for mounting above the passenger kick panel under the dash so thought I'd share some photos for anyone looking for mounting options.
To get to the mounting location the glove box and inner part of the glove box needs to be removed. Very simple process takes no longer than five minutes.
I used the existing thread holes up under the dash to mount the UHF holding bracket, just had to slightly enlarge one of the slots on the bracket itself and if all fitted up nicely.
The hand piece is plugged into a socket made by lightforce that fits into one of the prado blank switch locations, I used an ethernet extension cable bought from jaycar that goes from the UHF to the back of the lighforce socket.
Can post more photos or info if needed.
