Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
  1. #13
    Out of control poster! amts's Avatar
    Join Date
    Jun 2009
    Location
    Adelaide, SA
    Posts
    9,604
    The fridge and solar is showing the right wire gauge - 6B&S. The first link doesn't say, and the 2nd link says 8B&S. So I wouldn't get either of those 2.
  2. #14
    Quote Originally Posted by amts View Post
    Haha no problems, I like the idea of having Andersonís and just plug and play but might be wishful thinking!
  3. #15
    So for me it looks like the best solution is to have the setup as showing in the following image, this site was incredibly informative and very helpful if anyone plans on taking on a dual battery system project.
    I probably wont carry out the project for awhile.
    Instead of having the anderson located on rear of car have it located in back.
    The one final question I have is as he mentions in the quote below
    "All cable lugs used with the 6 B&S cable are far too big to be crimped with standard crimping tools, so they should be crimped by an auto electrician, or you can solder them if you have a gas torch, they do take a lot of heat to solder on properly."
    Any suggestions on the best way to go about this myself is buying a tool worth it or would it cost just the same to get an auto electrician to sort out the lugs?
    Also any more suggestions on if this is the best route to go or any tips let me know.
    Advanced Member Brett1979's Avatar
    Join Date
    Jan 2010
    Location
    Lockyer Valley, Qld
    Posts
    768
    You could buy an Anderson Plug crimping tool off EBay for $17-$18. It's designed for larger lugs. Double your wiring back over in the lug prior to crimping for a mechanical strength fit. Even get two pairs of hands on the crimping tool when crimping if need be to add 50% more to your own strength.
    98 GXL 3.4L V6: TJM 2" lift, Airtec snorkel, TJM T15 steel bull bar, 8500lbs T-Max winch, 100w Roo Lite Spotlights, TJM alloy roof cage, Dual batteries, breathers to everything, TJM Air Compressor, Comforser CF3000 muddies. Home made battery box to power the camp site. ODO = 374,000km.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
