Hi Folks, after doing a fair bit of searching all over the net, including this site, I saw there were very limited options for installing an ARB on Board compressor under the hood of a 150.
Especially if you are running a dual battery, dual fuel filter, and catch can setup.
I had a play round with some 3mm plate, and figured out a way to mount the compressor between the air filter box, and brake master cylinder.
Fits perfect, and too under an hour to make, and uses the shafts of existing body bolts to hold everything in place.
Zero rattles, everything is still accessible, and the install location is tidy.
Maybe this will be of use to someone, maybe not.
