Avenger Mako TDS9.5 i
  • Avenger Mako TDS9.5 i
    Has anyone managed to fit one of these behind there sovereign bull bar ?
    Was looking at one 1 of these then came across this
    http://www.avenger4x4.com.au/library...nchComparo.pdf
    And it made my mind up, Just not sure if 1 will fit there or not ?
    Any help with this would be great
    Graham
    Graham
    Hi Graz
    I have purchased one of these winches and hope to fit it to my prado in the next coming weeks.
    I have purchased the winch craddle from Toyota and i have had to also get the Fairlead from Toyota as the one supplied with the Avenger will not fit in the soverign bar and although there are posts on Prado point of others that have modified a fairlead to suit the soverign bar i looked at it and i saw that i would have to butcher the fairlead to get it in. The pain in the backside is that you need to remove the bullbar and refit it with the craddle and winch all together so there is quite a bit of weight involved here so you need a few extra hands.
    2008 Prado VX 3Ltr D4D Auto Dual Batteries , Soverign Bullbar with Avenger Mako TDS9500lbs Winch, Ironman Snorkel, Hayman Reese heavy duty Tow Bar Gme uhf Tx3100, Double din Radio, Gps DVD, Bluetooth , Narva HID Driving Lights , Pedders Trakryder Suspension, BFG A/T, Foxwing, Tekonsha P3 Brake Controller, Alternator Voltage Booster
      Thanks for the reply Muzza
      I will wait and see if you have any luck getting it to fit your Prado before i go out and get 1.
      So when you get the time to try it out please let me know how you went
        will do I'll post some pics when i get around to fitting it
          Ok so i fitted the winch today
          A few modifications need to be done to fit the Avenger Mako winch to the Sovereign bar.
          I had to grind two of the corners of the winch housing as the bolt holes didn't line up . the bolts supplied for the winch to mount it to the bullbar are not long enough as it needs to go through the bullbar and the winch craddle you need to get 4 10x1.5 bolts at 40mm long . and as mentioned previously the fairlead i used was a genuine one as the one supplied was never going to fit in the bullbar housing I'll upload some more photos later as it got too dark to take anymore of the finished product From the photos you'll see where i had the grind the housing to make it line up
Name:	2012-08-05 11.48.19.jpg
ID:	640600Click image for larger version
Name:	2012-08-05 11.48.27.jpg
ID:	640601Click image for larger version
Name:	2012-08-05 12.02.19.jpg
ID:	640602Click image for larger version
Name:	2012-08-05 12.40.40.jpg
ID:	640603Click image for larger version
Name:	2012-08-05 13.32.05.jpg
          muzza_
            some more photos
Name:	2012-08-05 14.21.21.jpg
ID:	640605Click image for larger version
Name:	2012-08-05 14.21.30.jpg
              Your a champ Muzza
                Finished product and photo showing where i mounted solenoid box
Name:	2012-08-06 07.22.27mod.jpg
ID:	640623Click image for larger version
Name:	2012-08-06 07.23.10.jpg
