Radio upgrade , 2015 into 2008 Prado
  • Radio upgrade , 2015 into 2008 Prado
    Hi, I have a 2008 Prado and want to fit a radio/gps/rear camera radio from a 2015 Toyota 86 (PZQ60-00537).
    Has anybody done a similar retro fit?
    I really need both sets of radio wiring diagrams and , so far have been unable to find a complete one for either. I also need a source of connectors as 3 are different. And pointers in this direction?
    Pzq60-00535 fits straight in no worries, I can't see the 537 unit having any different connections on the rear. You need adapters PZQ60-00141 & PZQ60-00161. Enjoy
    [LEFT]Silver 150 Facelift
      i have just fitted the PZQ60-00535 it fits straight in no worries, I used the adapters PZQ60-00141 & PZQ60-00161 as AussieAndy said
      you should have the wiring through the car for the rear camera (if you buy one!)
      if you need any help send me a PM
      James
      still trying to work out how to get the satnav to tell me how fast i am going ??? everything else works a treat
      way better that the Kenwood DNN9150BT i fitted for $1500
      the PZQ60-00535 is on sale on ebay $565 delivered
      Razorback81
        TBH, if you are going to spend $500+ on upgrading to just another factory radio, id seriously suggest going after market.
        I haven't seen a factory head unit that out performs a quality after market(pioneer/Alpine) head unit yet.
        Sound quality & power alone is well worth it - it'll make your standard car audio system sound better than it ever will!
        Having said that, if you can get the factory upgrade one cheap then go for it.
        But you can get a good Pioneer unit for $500 ish.
          does that pioneer unit have sat nav ?
          i fitted a Kenwood DNN9150BT into mine cost $1500
          was told all sorts of stuff , like speed camera locations etc, when installed
          had issues reading the screen, no speed alerts ( they dropped it for this model i actually wanted the DNN9350BT was told it was the older unit )
          so i argued for a while and ended up returning it for a full refund
          brought the Toyota 4" screen to get the camera function , then found the latest large screen unit
          screen is easy to read
          sat nav works pretty well ( still working out how to show my speed ???)
          blue tooth works but might get the external mike from Fujitsu 10 around $90
            This is the one I have:
            http://www.pioneerelectronics.com/PU...rs/AVH-X4500BT
            Its a few years old now, but still love it!
            Reversing camera, bluetooth streaming & bluetooth mic, full ipod integration - everything works spot on, probably the best head unit I have owned.
            I bought it from sonic electronix in the US when the dollar was good, ended up about $550 delivered.
            It doesnt have built in navigation, however it is compatible with the pioneer plug in navigation AVIC-U250 which you can pick up for $400-ish and then it will work as a fully integrated system.
            I was going to go down that route, however once I got it installed, I was using google maps on my iphone whilst it was connected via bluetooth & it actually gives you turn by turn navigation via the headunit - it just comes up as a phone call, gives you the direction & then goes back to playing music.
            So I never bothered as it works just as good as integrated navigation - and is a lot more user friendly whilst using your phone to figure out your destination!
              Hi,
              Thanks for all your advice.
                Hi,
                I bought the adaptors PZQ60-00141 and PZQ-00161 ( only needed the aerial) I have the head unit working and the steering controls respond but I have no sound! The power and speaker plugs from the car fit directly into the radio. Any ideas?
                PZQ60-00141 has 3 long cables, one purple & white, second is red and the third green with a fuse holder. Does anyone have a wiring diagram?
                  The PZQ60-00141 is the wiring loom for the reverse camera only. The sound should work without it. Purple and white then green is all that is needed. I did it a few months ago and connected the cables with the supplied scotch locks to other cables in the left side of the passenger footwell where the ecu is. Unfortunately I dont have the exact instructions I got from my Toyota dealer anymore
                  I had the same problem with no sound when I installed the same stereo. I checked and rechecked every cable a few times. Then magically 1 time it started working. I figured it was either a loose wire or plug that wasn't sitting quite right
                  2008 Prado 120 GXL V6 auto. Stock...but slowly building it up
                    Hi,
                    Thanks for the info.
                    00141 also connects up the steering wheel controls. I have tried as you have done many times but still no luck re the sound. When I reconnect the old radio everything works.
                    what Toyota dealer did you use, my local one know nothing!
                    Thanks Dave
                      Originally posted by tappets View Post
                      Hi,
                      the purple & white is the speed sensor
                      the red is for the handbrake ( but i connected it to earth)
                      green is the reverse wire
                      i think you will need to use both the adaptors as one is a 20 pin to 28 pin
                      mine used all the plugs and worked straight away
                        Just make sure that the wires on the back of the connectors matches with a corresponding wire on the mating connector.
                        Also check for bent pins in the connector.
                        Then also check that the large connector to the left of the AC controls are fully seated. I'm not sure if the audio wires goes through this connector but have experienced the lack of power to the center console when this plug isn't seated all the way in.
                          I have a good relationship with the parts guys in Castle Hill Toyota. Some of them really know there stuff and are able to find the unusual stuff for me then they print of instructions from I presume the service /install manuals
                            Thanks for the info. I live in Melbourne so will try another dealer.
                              This. +1
                              I've always run after market double DIN units in my cars, with GPS functionality. Been super reliable (Alpine), no problems yet, touch wood. There are plenty of swish single DIN units with fold out screens too, that would allow for a two-way or some other toys to be mounted neatly underneath. I'm very much a fan of the OEM look. There are lots of units out there these days that look very clean, not necessarily all bright colours and flashy lights, like was the rage a few years back.
                              As Topic97 has already said, going after market will give you better sound quality too. Not only that, but it also offers a lot more flexibility. In the future you might decide to add a monitor(s) in the rear for the kids, amplifiers, digital radio, TV receiver, etc. Many after market multimedia units also have good auxiliary functionality, allowing numerous formats of connections in and out for audio and video. Newer models are even starting to come with HDMI inputs/outputs, so you can plug in a laptop if you are that way inclined. How many factory units can do that...?
                              Most brand name units will have optional support for steering wheel controls too. None of my cars have ever had steering wheel controls, so I can't comment first hand, but reading on other forums suggests the interfaces are pretty reliable.
                              Also, don't be scared of something just because it isn't plug and play. Modifying is half the fun, and you get a real sense of achievement when you've "custom fit" something after market into your car yourself. If you're even remotely handy with a soldering iron, and know how to measure voltage and resistance with a multimeter (not hard to figure out if its your first time), you've got it covered.
                              Apologies if I sound a bit passionate, I'm a bit of an audio nut (and a sparky by trade).
