See more
See less
Cool box fan
  • Cool box fan
    Does any-one know how to replace the Centre Console Cool Box fan in Prado120?
    Toyota want to remove the entire centre console just to replace the $80.00 fan. This takes 4 to 5 hours and means disconnecting the gas lines, and re-gassing on re-assembly.
    There must be a smarter way. Even if a bit of plastic has to be cut!!
    Paul
    Interested to know also as i have the same problem, is the fan only 80 bucks?
      $79.99 to be exact, p/n88550-60120 Motor Assy, Blo J702 (That was from Toyota Spares and a small discount on RRP)
        Im going to start pulling mine apart tomorrow will post up once i work out a better way
          quadric, Did you have success getting the fan out? Paul
            Im going to have to do the same thing I think.
            I haven't done a 120 before, but in previous instances cooler boxes are usually put in as a whole unit unfortunately.
              Any joy fellas?
              I've been putting this one off awhile as I can't figure out how to separate the cooler box...
                Hi
                I replaced mine about four months ago. You reall need to take the entire console out in order to replace the fan. If you open up the console lid, you will notice there is a gasket. Peal the gasket off then you will see screws. You can peel if off carefully and reuse it if not you need to buy a new one. Once those screws are off, there is also screws on both right and left side of the console if you look at the rear AC controls.
                Once you have the console off, becareful with the AC pluming.
                Alan
                07 120 D4D Grande
                  Yes, fan replaced, but centre console needed to come out and A/C lines disconnected. As A/C had never been regassed, felt good idea. Done privately, 2.2 hours, less than half the time quoted by dealer.
                  All done just in time for summer.
                  Cheers Paul
                    Can confirm a/c does not need to be touched, just finished putting mine in and left all a/c attached
                      Don't mean to hijack the thread, but I've also read the same (in the service manual) regarding the need to disconnect & re-gas the AC in order to perform the park brake cable adjustment in my 150. Surely there's an easier/cheaper way for something that's a relatively common maintenance task?
                      David.
                      [SIZE=2][U]2012 150 Series D4D Kakadu[/U][/SIZE]
                      [SIZE=1]Wynnum Towbar, Narva Merit/USB/lighter sockets, Pirahna dual battery tray, Redarc BCDC1240, Xantrex LinkPro battery monitor, 600W inverter, ARB onboard air & WaterWatch on AMTS bracket, Phillips 35W HID high beams, UHF, Roadsafe front recovery points, Offroad Systems drawers with integrated water storage with tap concealed in rear tailgate, ARB 47L fridge.[/SIZE]
                        Am about to try and fix my fan anyone have any hints thanks
                          I have the same problem, any input to fix will be great. Just been quoted 5K from local Toyota dealer for Prado 150...seems BS to me.
                            My fan stopped working also. When I was pulling apart the centre console to access the fan I found a stand alone 2amp fuse attached to the wiring harness. Using a meter, I confirmed the fuse was blown. Replaced fuse and fan is now working.
                              I just sprayed a shit ton of repco contact cleaner in the top part of the fan and checked the small fuse panel, pulled fuse out and in and now it works again... Hopefully for a long time
