Maxtrax
    Snaga
    Wishing I was lost
  • Snaga
    replied
    Sadly no... It was a very quick visit to pick up the range of colours for more product shots.
    Leave a comment:
  • craigm
    Addicted PP Member
  • craigm
    replied
    No sneaky pics?
    Leave a comment:
  • Snaga
    Wishing I was lost
  • Snaga
    replied
    I saw the penultimate prototype of the new spare wheel carrier for the Maxtrax yesterday... looks good. Nice and quick to use. Very secure and is made to allow for a few inches of caked on mud after use
    Leave a comment:
  • Prado BB
  • Prado BB
    replied
    Nice job Quicky/Craigm, I like both ideas
    Leave a comment:
  • craigm
    Addicted PP Member
  • craigm
    replied
    Never got a chance to post a pic of the brackets all mounted up so here's one. Nice n quick to mount/remove the maxtrax. No noise at all. Very happy with them.
    Leave a comment:
  • craigm
    Addicted PP Member
  • craigm
    replied
    Nice work Quicky. Great solution with the Posts and you have no issues with anyone fogging your maxtrax brackets and all. (unless they want walk down the street with the entire roof rack assembly...) I might get something similar made up for those day trips when I don't have the cage mounted as well. (might even be able to drive into the garage with them on unlike mine).
    Craig
    Leave a comment:
  • foxclan
  • foxclan
    replied
    One of your best Quicky, One of your best.
    Currently using a bloody bike cable for security. Its a bit long so need to make a couple of wraps around the maxtrax to take up the length.
    Not what you would call easy access.
    i like your lynch pin attachments.
    Cheers Troy
    Leave a comment:
  • QUICKY
  • QUICKY
    replied
    On the weekend I knocked up some brackets to hold my Maxtrax on the roof rack.I welded some flat bar and round bar to form the brackets then drilled them to bolt to the roof rack. The round bar is drill to take a lynch pin in each post for easy retaining and quick removeall if needed and for security if needed while having an ale after a day on Stocko remove a coulpe of lynch pins and replace with a pad lock
    Leave a comment:
  • craigm
    Addicted PP Member
  • craigm
    replied
    It was what was lying around at the time. yeah they're certainly not going to fold on me if I hit an overhanging tree. Most likely get ripped of the roof racks first!
    Leave a comment:
  • Guest
    Guest
  • Guest
    Guest replied
    Good stuff. Wow! 5mm! It would still be holding its shape in a rollover.
    Leave a comment:
  • craigm
    Addicted PP Member
  • craigm
    replied
    These brackets are 40mm x 5mm plate
    Leave a comment:
  • Guest
    Guest
  • Guest
    Guest replied
    If you made the brackets 40mm wide, they would also be suitable for those with HD bars mounted onto the factory rails.
    I found this issue with the Oztrail awning brackets (and I guess other similar awnings as well). If the brackets were as wide as a HD bar, you wouldn't need to drill holes into the web of the HD bar, etc.
    Leave a comment:
  • craigm
    Addicted PP Member
  • craigm
    replied
    Cheers for the positive comments Gents. A simple solution but I cant take the credit for the workmanship. I got one mate to weld up the plates and then pulled a favour off another to powder coat. I just drew it up with the support of people on this forum
    At this point the brackets are a one off but if there is genuine interest, PM me and if there are a few requests, then I can put it to the lads to see what can be done...
    Leave a comment:
  • Guest
    Guest
  • Guest
    Guest replied
    Beautiful piece of work. Would have commented earlier if it wasn't for work blocking photo sharing sites.
    Leave a comment:
  • MidLifeCrisis
    Out of control poster!
  • MidLifeCrisis
    replied
    Great job Craig
    Leave a comment:
