Quickly knocked this up in CAD
Not sure if Blackwoods has the stainless version according to this listing
http://www2.blackwoods.com.au/infoBA...3399&P=2024269
As for mounting it on its side next to the basket, 3mm thick will do and weld a nut to the other side. Or if you want to tap into it, at least 5mm thick material to get 3 threads on.
Just be wary about mounting the Maxtrax on the side because once you take all 4 star knobs off, it will fall on you. In your case, you might be better off with the female version. Then get a stainless screw and let it act like a stud on the flat bar and drill a hole in it for the padlock.
