Re: Sovereign bull bar fitting instructions
Hi MDSimpson
Ive got a good set on my computer at work so i'll email you a set tomorrow.Like I mentioned earlier make sure the whole fitting kit is there including the chassis pins and the two side brackets, was reasonably easy to fit made easier by using a genie lift to hold it in position while lining every thing up on my own.
Wayne
Thanks speedcomm, I'll look into that.
Anyone have the fitting instructions for the sov bar?
EDIT -- I have found it in the online narva cattledog. Now, finding stock and pricing...
Leave a comment:
The indicator light is a cheapy Narva item, im sure its p/n has been mentioned on here before. If you cant find it im sure a quick look in a narva catalogue would source some :wink:
Leave a comment:
OK, so I've just picked up the new old bar, yes, it is a complete kit, BUT the wires for the indicators/parking lights has been cut at the back of the light itself.
Easy fix with new wires or best to replace both units?? For the price I paid for the bar, having to buy new lights is big deal..
Leave a comment:
Hi, I also have just bought a 2nd hand bar. Apparently it has the full fitting kit, but I guess I'll not know until fittin time...
If you would be so kind as to forward a copy of the fitting instructions for me too my email is msimpson at continentalconveyor dot com dot au.
Many Thanks
Leave a comment:
Sounds like you got a great deal Good luck with the install
Leave a comment:
Well I dont feel so bad now.Got the Chassis pins and those two brackets that it each side of the chassis for $60 from Tony's wreckers in Midvale along with most of the bolts. Got the bar from a bloke in Mandurah for $300, so touch wood it should fit up ok. Will fit it next weekend.
Wayne
Leave a comment:
Hi Wayne,
I was lucky with mine. The guy who sold it to me included a new fitting kit so I got the lot; Including instructions the chassis pins and fancy bolts. I fitted it up yesterday and didn't need a single visit to Toyota spare parts dept. I think that I really lucked out. The unit cost me $1250.00. One Toyota dealer wanted $2250 and another $2420.00 for a new one. Once you get the fitting kit, my suggestion to you is get someone to help you install the bar. I did it by myself and it took most of the day yesterday. Worked out in the end but it was a bit difficult in a couple of bits. Only have to connect the lights (parking & indicators) that came with the bar. I found the instructions quite easy to follow but if you get stuck just drop me a line.
Pete
Leave a comment:
Yeh
Make sure all the parts are there. I got the instructions from LenGXV6 and it shows a captive nut called a CHASSIS PIN
and a large bolt that goes from the front of the bar through the chassis mount. Also a bracket that fits behind the chassis mount and bolts onto the lower chassis.
The bar I got didnt have these parts and it looks like I will have to buy the whole fitting kit to get them. My cheap bar doesnt look so cheap now.
I got the instructions so if you want them PM me and I will email them to you.
Wayne
Leave a comment:
Hi Spark,
Did you fit your bullbar? I've just bought a second hand bar for my D4D and plan to fit it tomorrow. Just interested to see if you have any hints for me from your experience.
Rgds,
Peter
Leave a comment:
Thanks LenGXV6
Just saw them. Much appreciated
Wayne
Leave a comment:
Originally posted by LenGXV6PM sent with instructions
Opened the PM but didnt get the instructions
Does anyone else have a set.
Wayne
Leave a comment:
Originally posted by sparksyThanks Hutch
Are those that I can see on the photo of your Prado.
Wayne
Leave a comment:
Thanks Hutch
Wayne
Leave a comment:
Leave a comment:
