Hi all,currently own a 120 08 gxl and looking at getting it more travel worthy like the 100 series i yad previosly. The current prado is completly stock with 56,000k on it. Still a baby. Im looking into getting a steel bullbar thats winch compatible. Ive always ran arb, but recently seen a tjm bar on one and it didnt look too bad. Whats everyones thaughts on build quality and strength for eityrr, or if there is another brand i should look into? Thanks in advance, matt
Arb vs tjm vs other bullbars
Whatever you choose make sure you inspect the quality of work undertaken. About three years ago, I had a TJM bullbar, siderails and steps fitted at its Myaree outlet in WA. Eighteen months ago while checking for a rattle underneath the vehicle, I noticed the bolts holding the running steps were half out. I decided then to inspect the rest of the work done. During the inspection I noticed the way the harness wiring was connected up to the wires coming out of the lights fitted in the bottom of the bullbar. No cable connectors were used instead the join consisted of the wires just twisted together and wrapped in insulation tape. Pity I did not find the shoddy work earlier as I would have raised hell.
