See more
See less
Grande Radio/GPS in GXL
  • Grande Radio/GPS in GXL
    Hi all
    does anyone know if itís possible to change the GXL radio to a grande sat nav / Audio system? is it the same wiring harness? is it interchangeable?
    should mention i have a 2008 GXL
      Not sure if all the wiring stuff is there (GPS antenna etc etc) but I'm betting no. You'd be far better off getting a modern aftermarket one anyway, or use your phone. I have my phone mounted on the dash with a magnetic wireless charger and use google maps for navigating and it works a treat. Old GPS hardware is fairly useless unless you can update the maps.
        The GPS in the Grande isn't self-contained, the DVD box is mounted under the drivers seat and would also need to be installed in your GXL.
        The navigation solution I use is a cellular iPad mounted on a RAM mount from the floor, bolted to the passenger seat mount bolt. This way you can use Google as well as Hema etc.
        "S[FONT=Arial]ure itís quiet, for a diesel. But thatís like being well-behavedÖ for a murderer."[/FONT] [FONT=Arial]- Jeremy Clarkson[/FONT]
          cheers guys appreciate the input
