Sovereign bar parts
  • Sovereign bar parts
    Howdy, I am chasing a driving light bracket for my bar and it seems they are no longer stocked - Part# 0859000001C
    Does anyone have any tips for how I might get around this problem?
    If you mean the plastic box the only place would be a wrecker.
      Originally posted by LeighW View Post
      I could be wrong but I think it is the same fog lamp that is used in the normal bumper,
      these are available on Ebay.
      I've got the lamp itself just not the fitting for it to be held into the bar.
        Only place would be wrecker
          Is it the grey bit your looking for?
          https://www.ebay.com.au/itm/Fog-Ligh...frcectupt=true
            Had another look, if it is the actual mounting box it will be a wrecker job, the bull bar was made in Australia
            for Toyota as I imagine the box was too. I doubt you would be able to source from anywhere else now.
              Appreciate your time mate.
              It's working out how to get these to lock into the bar without it falling out once I hit a bump as whatever was inside to hold it is no longer there. Sikaflex maybe an option at this point.
                If you glue it in no doubt you need to take it out for some reason.
                There's quite a few being wrecked at the moment if you do a search. Another option if you know someone who
                has access to a 3D printer they maybe be able to make a 3D imagine of the one on the other side mirror the
                image and print one for you.
                  I would be happy of a picture so that I knew what I was even looking for!
                  I can get access to a 3d printer I'm pretty sure...
                    Most people are only interested in selling the bar complete, need to find one that is all bent up but still OK on the left...
                      further pic that shows the bit I am on about...
                        Ring around any panel beaters in your area. They just replace the whole bar and stockpile the old ones until a scrap dealer picks them up.
                          Was out bush bashing on the weekend, and my left driving light came loose and was just hanging out. Removed the light and then the casing it sits in (part of the bar), and it looks like it just sits inside the casing using the two locating pins on the outside of the light. Problem I have now is its really loose inside the casing and I reckon its gonna come out again. I'm planning to line the casing with some foam rubber to support the light, and then sink a few screws through the casing to hold it in.
