Water drain grommet in rear quarter panels
  • Water drain grommet in rear quarter panels
    In the rear quarter panels, behind & under the air/dust filters, there is a small rubber grommet which allows any water to drain away (see pics). I'm missing one & would like to know what it is actually called & part number so i can try & buy one (amaysim etc). Anybody know what it is called?
    If no one knows i'll pop into Toyota & see what they charge for one; or alternatively i could make something out of say some flat-heat-shrink & a bit of sikaflex?
Name:	rear quarter panel - air outlet1.jpg
Name:	rear quarter panel - water drain grommet.jpg
    Hi mate
    i had a look on wwwToyodiy.com but the part is small and those sort of parts only appear as standard part, no name, best bet will be go to Toyota.
    2007 D4D GX 120 Alloy bar, Cruise control
      Thanks gx-d4d. I wasn't aware of wwwToyodiy.com so that's good to know too
        you probably won’t be able to see the diagrams unless you a member of the site.
          Part number 57442-95j00 I believe. Probably cheaper to buy it from Toyota unless you have other items to order from os suppliers.
