Water drain grommet in rear quarter panels
  • Water drain grommet in rear quarter panels
    In the rear quarter panels, behind & under the air/dust filters, there is a small rubber grommet which allows any water to drain away (see pics). I'm missing one & would like to know what it is actually called & part number so i can try & buy one (amaysim etc). Anybody know what it is called?
    If no one knows i'll pop into Toyota & see what they charge for one; or alternatively i could make something out of say some flat-heat-shrink & a bit of sikaflex?
Name:	rear quarter panel - air outlet1.jpg
Name:	rear quarter panel - water drain grommet.jpg
    Hi mate
    i had a look on wwwToyodiy.com but the part is small and those sort of parts only appear as standard part, no name, best bet will be go to Toyota.
      Thanks gx-d4d. I wasn't aware of wwwToyodiy.com so that's good to know too
        you probably won’t be able to see the diagrams unless you a member of the site.
          Part number 57442-95j00 I believe. Probably cheaper to buy it from Toyota unless you have other items to order from os suppliers.
