Second row seatbelts not retracting!
Maybe after cleanup of the guide, as suggested before, if still not working properly, what about some silicon spray on the guide where the belt runs against?Maybe on one side of the belt too.
- 1 like
Clean the top guides where the belt comes out of the plastic trim. Crud builds up on them over time, it's pretty common with most vehicles. Use a small screwdriver or something similar to scrape it off
- 1 like
Leave a comment:
Has anyone had issues with the second row seatbelts not retracting? Both sides need to be manually fed back in which I believe makes the vehicle not roadworthy!
The belts have not been contaminated with anything and I have lubricated the retracting mechanism without any change. It's as if the springs have lost most of their tension. They have been like this for several years.
Has anyone replaced theirs and if so any idea of cost?Tags: None
Leave a comment:
