Brake hose bent...
  • Brake hose bent...
    A stick has bent my aluminum hose feeding the front right caliper. What part number or advice can you suggest. Not leaking yet but its at a right angle
    Just bend it a little straighter again to how it might’ve been originally. Those brake lines can be bent back & forth rigorously before they break, kind of like the metal gas lines to gas bottles. If the line is a little flattened just use pliers to squeeze the line open a bit more.... Unless of course you definitely want to replace the brake line.
      Sounds great, I will give it a go. Thanks
      kartal escort
      sex vidio
