where is the Gear box breather on a 120 2007 GXL Diesel
  • where is the Gear box breather on a 120 2007 GXL Diesel
    Hello all,
    I have seen a few posts on this but none of it seams to be right,
    so i swapped out my radio the other and thought why i was at it i would do the gear box breather by taking off the gear leaver rubbers.
    however i took them all off and there was no breather.
    where is it? and how do you get to it? do you have to drop the gearbox out?
    all the information i can find says its on the top of the bell housing and some same you can get it by removed the gear leaver rubber...
    regards,
    Leon
    Yes- on top of bell housing where it joins motor. 3 hoses to be done. Lots of links on here if you search. eg today I posted one in the 150 modifications. basically the same, but more room to work on the 120. Google pradopoint, 120 gearbox breathers to start.
      sorry i should of put Manual gearbox breather. I've found heaps on the auto ones but not a lot on the manual and some of the info if seen for the manual doesn't match up with what im seeing...
