Has any body looked, seen, or read about the new eaton e locker sold buy Harrop Eng. Advert in 4x4 aus mag.Look good, but a bit expensive.$1695. for prado rear,but no compressor,hoseing, or air leakes to give problems.
Eaton ELocker
In the States they are called Detroit Lockers.
Stolen from Eaton.com.
They are used mostly on Jeeps and heavy trucks with the Dana 44 & 60 axles. The FJ comes with rear a locker OEM, and utilize the A-TRAC system, so there is not much need for an additional locker. If an FJ owner adds one it's usually an ARB air locker. They seem to have cornered the market " up here".The legendary Detroit Locker began the revolution in performance differentials and still leads the industry today as an Eaton brand. The Detroit Locker is the most durable and dependable locking differential available.
-Ben"Don't worry about the world coming to an end today. It's already tomorrow in Australia" (Charles Schultz)
I have a 2007 FJ Cruiser (An American knock-off 120) Considerably built up.
I am also a Founding Father of the FJ Bruisers, FJ Cruiser club, in Washington D.C.
Check us out....
[url]http://www.fjbruisers.com[/url]
Our discussion forum....
[url]http://www.fjbruisers.org/forum/[/url]
$1695 doesn't seem too bad when you add up the price of an air locker +compressor.
I'm sure I read the article / ad in 4x4 australia about their release for Toyota and I think it was even mentioned they were "factory approved" which would make you think it wouldn't cause any warranty hassles.[color=#BF4000]2003 V6, Auto, GXL, Factory Bullbar, Rhino Roofbars, Bosch and Hella spotties, Cooper AT3, Bilstein shocks, Ironman awning, GME UHF, MaxTrax.[/color]
[url]www.kymarphotography.com.au[/url]
Re: Eaton E,locker
So has anyone fitted a detroit (eaton) soft-locker to the rear of a prado yet ?
I found the importer but I think with the Aus$ down the toilet it might be worth waiting til it gets a bit higher
http://www.locked-drive.com.au/index.php
Or has anyone imported one of the FJ cruiser rear lockers from the states ?
Seems really weird why toyota don't offer lockers as an option in Australia."Ooops I just deleted the internet, lucky I was able to recover 99.7% of it out of the bin" :lol:
Re: Eaton E,locker
There is no way I would fit an auto locker to the Prado as it is awd. You are better off spending a couple of hundred extra on an air locker. I have driven vehicles with Detroits in the rear and would never have one myself. I did run an auto locker in the front of the Lux and loved it, if the Prado was a parttime 4wd itd already have one in it but being awd its not an option.[color=#BF0000]Trail Toy - TJ Wrangler with some mods and some bling
Wifes Daily and Tourer - V6 120 Prado, some mods wife wont give me the keys.[/color]
Re: Eaton E,locker
Hey Boof,
Have you seen or heard of these new softlocker (sp?) versions that apparently use 2 or 3 stage lock mechanisms (no audiable sound) and have been recommended by some for constant 4wd ?
I had one of the early ones in a discovery, which made a terrible almost terminal sounding noise each time it locked ?
Cheers"Ooops I just deleted the internet, lucky I was able to recover 99.7% of it out of the bin" :lol:
Re: Eaton E,locker
Hey mate I have driven a couple of vehicles with the series 4 softlocker. While they are better than the cheaper auto lockers they are still noticable, the other thing is they are as expensive as an air locker so I dont see the point. I would always prefer a switched locker over an auto in an AWD vehicleOriginally posted by SpurioHey Boof,
Cheers[color=#BF0000]Trail Toy - TJ Wrangler with some mods and some bling
Re: Eaton E,locker
The Eaton Elocker is not the detroit locker,It is a manual locking diff that uses a electromagnetic locking mechanism, not air. like the arb, tjm lockers.These are the same lockers that are fitted to the H3 hummers at the factory. My old 75 toyota had a air locker in it in the mid 90s and the quad ring kept failing and leaking air,That is why i got intrested when i read about these, as i am looking at some type of manual locking diff for the prado .06gxl.auto.arb,roof rac/bullbar.hella spotts.duel batteries.ome suspension.saf snorkel.mickey thompson ATZ 4 rib
Re: Eaton E,locker
They come standard on the new Mitsubishi 4wds & Jeep Wranglers
Originally posted by way/belHas any body looked, seen, or read about the new eaton e locker sold buy Harrop Eng. Advert in 4x4 aus mag.Look good, but a bit expensive.$1695. for prado rear,but no compressor,hoseing, or air leakes to give problems.2007 D4D auto, Tunit Power Module, Scan GaugeII, Bilsteins & lovels HD, raised 50mm front & 60mm rear, 10,000lb Tmax winch, 7/16th Amsteelblue synthetic 23,000lb winch cable, TiTan HD winch solenoid pack, Outback draws with fridge slide & 50 litre Waeco, Ryno roof rack & Alloy Cage & extra set of Rhino HD Roof bars x 3, TJM type 15 steel Bullbar powder coated silver, Dual battery setup with custom tray, Bosch Navigator spots with 55w HID kit, Sand Grabber mats, Toyota Tow Bar, Sensor Touch Electric Brakes, Cooper ST 265/70/17 tyres, Uniden remote head UHF radio, Modified Milford Cargo Barrier, Extra power points in the back run with 10mm wire for fridge & inverter, Anderson plugs with 10mm wire front & back for the camper & compresor conections. 7 inch in dash JVC DVD player with bluetooth & Ipod adaptor, 39DB Stebel High Power TM80/2 Magnum Electric Horns. JL Audio 300/4, 300/2 power amps, Pioneer TS-C160R front splits & TS-D161S rear speakers & 12" Pioneer sub
Still need to fit some heavy duty engine & transmision gaurds, snorkel. 9inch headrest monitors
Re: Eaton E,locker
4X4 Custom Action has a comparo of the various Lockers on the market... the E.Locker is mentioned but the article left me with more questions than answers
The article says the ELocker is a manually engaged locker (but without using air)... the main point is their reference to 'unconfirmed' reports of the locker not fully engaging possibly causing extra stress on the mechanism.Cheers, Leon
Optix Photographix
Re: Eaton E,locker
The Kakado and ZR have a factory fitted E Locker (unless you get the Cruise pack). Some overseas models of the 120 also came factory fitted with the Toyota version of the E Locker for the rear diff. I think the guy with the shorty in the UK has one.
NeilWhite 2013 GXL 79 series dual cab, ARB GVM Upgrade, ARB Delux winch bar and scrub bars, GME TX3440 and much more to come
Snaga
