Re: Grease Nipples?
On last Toyo service I noticed a lot of black grease that had been thrown out of the uni joists which looked very much like a grease with a moly content,this is a big no no for uni joints as moly tends to "build on its self" which could slightly restrict the grease galleries in the uni-joint.. If there was a slight restrction when you pump grease into uni the grease will flow in galleries with the least resistance,hence if you grease until you hear air escaping "slight popping noise" you may have" not lubricated all four bearing on uni..Alway pump very slow...lly to let lub flow to all four bearing this will also reduce risk damaging the seals.. I pump very slowly until I see lube slightly escaping from all four bearing...
ps Toyo owner manual states a Lithium base NLGI 2 grease in Spiders (uni joints) and only moly type or Lithium in Slide yoke.. Also use a impact resistant and water proof greese "simple test mix some grease with water in parm of hand then place on you work bench and hit it with hammer dont wear your best cloths as you will have a new pattern on your pants" ,I use a Lubrication Engineers product LE1233 it will resist throwing out "yes I work for them :? "If you are in Vic or Tas goto a William Adams "Cat" dealer as they are a reseller "they also have thier own branded product!!!"it is at least double the price of most.. but you get what you pay for.. If you live outside vic or tas give me a message stating were you are I'll find out nearest supplier..
