Dirty plug. If you are running a flat plug the indicators are at each end. If the plug has been wriggled back and forth and wretched out the pins can close up. Check if you have a signal at the plug on the car. If yes then it is a trailer issue and work through that otherwise it is at the car. Check you have power across the fuse too or put a new one in anyway because these things can sometimes fail but look fine.
Trailer Indicators - Fuse?
