Re: Spot/Driving light wiring diagram
I posted a similar reply yesterday and read it afterwards to make sure it was accepted, but for some reason it has disappeared from the thread, so I am posting it again today.
Sorry to add more confusion to this thread, but you can NOT necessarily pick the high beam wire by using a multimeter/test light on some modern cars.
I tried that and found that on both my 2001/95 series and my son-in-laws 2009/120 series you will find power on more than one of the three sockets if you leave the other headlight socket attached and if you disconnect the second headlight it will change again and you will only get power from the right hand socket.
I have no explanation for this so I rang RACQ and they were not able to explain the detail of the situation, but said electronics is no longer simple like it used to be and made comment about the need to buy a separate wiring harness for a trailer socket for modern vehicles, because you just can't find the relevant live wire and attach the trailer plug to it like we used to do.
The only analogy I can come up with is broadband computer wiring, where you can use your phone and the computer over the same wire because the messages come at different frequencies. I am not saying this is the same, but it might help to answer the question.
Sadly DIYers are becoming redundant for some tasks on modern vehicles.
Brian DJ
Brian DJ
