A/C Fan only works on high
  • A/C Fan only works on high
    Hi first post here
    Was chatting with a mate and his prado 120 GLX A/C blower fan only works on high speed.
    How do we fix?
    Do they use a resistor/coil to contol the fan speeds or is all controled by the switch and the ECM.
    150 Prado D4D GXL Blue Storm, T13 TJM Bar, 265/70/17 Goodyear MTR Kevlar, Tigers11 1200 pound 2 speed Winch, Fox Shocks remote resevor, Air tec Snorkel, ARB Air Lockers Front and Back, Off Road Systems Draws with Drop Down Fridge Slide, Wetsuit seatcovers.
    Re: A/C Fan only works on high
    If its a GLX with standard AC (not climate control) then check the dash switch and dropping resistor (The dropping resistor is located on the fan housing/behingd the glove box)
    Mick
      Thanks for the reply.
        No worries, let us know how you get on...
        BTW welcome to the forum.
        Mick
          I had my fan speed resistor go a few weeks back, and based on the instructions provided here, and looking at a few photos through a google images search I managed to find and remove the faulty resistor. I'm not handy around a car at all, but it's a pretty easy task.
          I then rang around a few wreckers to see if I could find the part, thinking that a genuine Toyota part could possibly cost an arm and a leg. A local wrecker had the part for $40, but by the time I got to them, they had sold the whole dash! On the way to these guys, I thought I'd pop in to Toyota for a laugh, which is what I got because the guy behind the counter couldn't tell me unless I had the VIN, even though I had all the other details.
          I got another lead a few weeks later, but the guy was going to charge almost double for the same part. I ended up calling another Toyota dealership, and got excellent service, and was quoted $56, with the part in stock.
          So, for anyone going down the wrecker path, I suggest checking with Toyota first. For the manual fan speed resistor it's part number 8713860270.
          2003 GXL V6
          Safari snorkel
            Thank you, that's exactly what I was after.
              Fan speed selector switch
              Hi there i am new here and i know a lot about not much at all really..... but I have problem with my Fan speed selector switch..... my air con was really noisy and took in to a Motorama dealership to no avail.... except a $1100 solution which i refuse to partake in..... so I take out the fan motor blow out all dust and throw some dry lubricant in. The noise has settled somewhat but now my fan speed selector switch makes the unit work at full pace or not at all.... please help 30plus degrees heat doesn't do me any favours!!!! I have a 5 speed Prado 2004 running on petrol 4 cyl. if that helps...... btw love taking it on the beach from time to time!!!!
                Exactly the same as mine, full on or nothing at all. Change the fan resistor for $40 and she'll be as good as new.
                Check out my rig build, page 10 post #140.
                Good Luck
                  Good Luck
                  Thank you..... but because i'm not a techie.... isit possible to show me what the resistor looks like? Can't find pge 10 sorry :roll:
                    Ring toyota and check, wreckers are notorious for ripping us blind! they just make up prices. I had my sensors in the rear doors go recently which turn the lights on and off when opened and closed etc. I rang a couple wreckers who wanted about $200 for the pair. Brand new from Toyota they were about $50 each. I told the wreckers to do their research and check out how much new products cost before trying to rip people blind!
                    Tossers....
                      Try this link, specifically post #140.
                      http://www.pradopoint.com/showthread...l=1#post427293
                      Just ring Toyota Spare Parts and ask for a "Fan Resistor". From memory it's located on the right hand side of the front passenger footwell. When you have the new one, you'll know what you're looking for.
                        thanks a million, worked a treat. Genuine toyota part cost €36 here in Ireland
                          I'm glad I'm not the only one that had this issue. On the 2003 Prado I recently got, the fan is either off or goes straight to arctic blizzard when it's on. Not that this is a bad thing in Australian summers, but you can't hear yourself think.
                          I can't find the right one online, so I'll order one from the local Toyota dealer.
                          Cheers.
                            Related thread: https://www.pradopoint.com.au/forum/...en-metal-strip
                            Radix
