Hi all, here is the issue...once again appreciate the help...
Right side headlight works fine
Left side not working
When I remove the fuse for the RIGHT side, both lights come on with only half beam (so splitting the voltage of one light between both)
obviously a short somewhere, but before I have to rip all the circuitry apart I just thought if you guys have any ideas or tests that could help locate the problem I could try them first?
I do have a duel battery setup and I have taken the other battery out of the car while checking.
I really don't believe that the original Toyota circuit could be to blame but if anyone else has had issues this is the place to come.
