Hello everyone,
first of all, sorry for my bad English, I'm from Germany and giving my best that you understand me.
I guess you are the only chance to help me, because in german forums they don't know anything about the problem.
The problems began 2 weeks ago.
First of all, my ABS and handbrake warning light came on.
I rode the car to work, started it after work - error was gone.
The next day, the error appeared randomly, but constantly more often.
I pulled the trigger and buyed a Delphi clone from China.
It told me
C0210 - Wheelspeed Sensor back right - wrong signal (I'm trying to translate the fault codes).
Allright, started live view and I could see that all wheels measure the same speed going in a straight line.
After that, I ordered a not genuine ABS sensor, just in case...
Two days later, Airbag light came on. I thought "wtf is this? Now every electronic want's to die????"
I used Delphi and found the following code
B0101 - driver airbag ignition pill - current open
That really sucks, because I need the car for work. Ok, it drives, but that's no long term solution.
Today, I installed the new ABS sensor. I was sure that it will be ok, but nothing!
Same error, I'm unable so erase the error via Delphi.
I took it for a ride - and indeed - the sensor on the right rear wheel shows NOTHING. No speed.
Yes, cable is connected :P
And I found out that the airbag error comes on when I park the car into my garage - going backwards and holding the steering wheel to the maximum right.
Is there any chance that some animal ripped my ABS line outside of the car ? But the airbag electronics is only inside the car?
Any ides what to do next? How can I measure the cables or what would you do?
Thanks a lot, I really appreciate your help!
Regards
Reno
It told me
Regards
Reno
