Hi Team
I have just recently had my 2005 Petrol V6 auto Prado 120 with a no start condition. It cranks but does not fire, has the immobiliser light flashing whilst cranking, an obvious sign its an immobiliser issue.
I have replaced batteries in the keys however same symptoms.
I have then removed the transponder unit from one of the keys and pushed it up close to the ignition barrel with ignition on, immobiliser now switches off and I can start the car. Have checked all connections to the immobiliser amplifier (module surrounding the ignition barrel). It just wont turn the immobiliser off while the transponder is in the key, like it has a weak signal or something.
I suspect maybe the immobiliser amplifier isnt working as well as it should. Anyone had this issue? Thoughts and theories.
