I have replaced the broken fog lamps with new replacement units, but the wires coming from the lights go into the engine bay into a three pin plug with what appears to be a blank insert to keep them dry, but there is nowhere to plug them into when i remove the insert. The lamp stalk inside the cabin has the requisite fog lamp on/off switch and dash indicator and the fuses check, out but the lights do not plug into anything on the wiring harness in the engine bay - any help is appreciated
