Wife noticed the switches to raise and lower the rear windows was not working from the master controls on the drivers door after a removed the Negative terminal from the battery the other week.
After a quick google, i foundh the following solution (not yet tested though), should it assist anyone else down the track.
The procedure to normalise the power windows in the 120-series Toyota Prado is:
Push down the power window switch on each door and lower the window halfway.
Pull up the switch until the window closes and hold the switch for a second.
Do this to the three passenger windows using the switches on their respective doors. The master switch on the driver’s door now operates again.
Apollogies if this has been covered before in a previous topic.
