Fuel Pump Relay Missing?
  • Fuel Pump Relay Missing?
    Hi. I have a 120 from 2009 with a 3.0 D4D Diesel engine that has been standing in the garage for over 8 years. Now the engine doesn't want to start. It seems to be all right, except that the fuel is not reaching the engine. I noticed that in the diagram of the fuse and relay box of the engine bay one appears with the designation "FUEL PMP" in the lower left corner. This relay is not installed in my car, as can be seen from the attached photos. Can you confirm that yours have this relay installed? Thank you for your help.
    My 120 D4D hasn't got one there so I assume its for the petrol or something!
      Likely for the petrol or maybe the Fuel pump heater for cold climates.
        Have you drained the tank and changed fuel and filters? When you say it doesn't want to start. Is it cranking, etc? What symptoms. I would be having a fluids drop and flush done on Engine and trans, and all fuel dropped and filters at a minimum.
          Thank you for your answers. He is cranking, but the engine fails to start working. We tried with some aerosol on the air filter box, and the engine starts working for a few seconds, but then he dies. I am planing to empty and clean the fuel deposit and change all the filters. Thanks again.
            Ummm Yeah. 8 year old fuel = your issue. I would be running a fuel cleaner thru it as well, wouldn't be surprised if the tank needs removal and cleaning sitting that long. I would also be changing the engine oil before starting it.. 8 year old oil = bad.. You could destroy the motor this way.
              Thank you, Piggy, I will do as you suggest.
              kartal escort
              sex vidio
