radio code
  • radio code
    Hi I was wondering if I disconnect the battery would I need to put a code in for my sat nav and my radio to reactivate them?
    yes. and its normal the last 3 or 4 digits of ya vin
      hi thanks for replying my car is a 2007 Landcruiser invincible 3.0 D4D 120 series is this still the same for my car and apart from the radio and sat nav what else would be affected?
        You will have to reset the electric windows. Search on here, easy to do.
          You can if you are only disconnecting to replace the battery, turn everything off and connect a 9v battery to the battery terminals before removing battery. It should keep the memory for radio intact.
            It will also afffect your power windows See page 325 of manual for instructions https://toyotamanuals.com.au/docs/la...jul-07-aug-09/
            Pedro
            2007 D4D Auto
              Thanks everyone for replying I appreciate it the reason I needed to know is because I will be attempting to change the timing belt and water pump and was thinking of swapping the batteries for a modern maintenance free battery?
